Lordoftheflies
Active Member
Insulation delivered. 44 bags. 33lbs each. 1320lbs total.
I picked up some Nashua extreme weather tape (2 rolls).
https://www.homedepot.com/p/Nashua-...reme-Weather-HVAC-Foil-Tape-1207801/100507541
I will have to use spray foam on the bigger gaps and harder to reach areas where I won't be able to get the tape in there cleanly. My main concern is that the adhesive on the tape will inevitably fail some day.
My other question is if I'm sealing the rafters with the foam boards in the knee wall attic space, and then going up into the ceiling to put insulation on top of the ceiling, isn't that kind of doing both methods? I.e. method one is to keep the attic space as outside space and seal the kneewalls whereas method 2 is to bring the attic spaces into the conditioned space by sealing the rafters. I kind of feel that maybe I should just remove the insulation on the rafters and instead just seal the kneewalls (outlets, wires, etc.). Either way I'm going to have to rip up the floor boards in the knee wall attic space since I need to stop the outside air from slipping in between the joists of the ceiling of the first floor.
