Gluebusy
Hello!
I am remodeling a house from 1924 in Lancaster, PA. The second floor bathroom has a slab poured around the pipes. The joists are chamfered to a point at the top. I've removed the cement around the copper supply and drain lines, I believe these are from a 60's renovation. My plumber will replace with pex and PVC.
After rough-in, my plan is to backfill under/around the new pipes, pour new cement up to existing tile, then pour a self-leveler and install new tile.
My questions: what is the best backfill for a second floor? It seems the previous backfill was pumice, or similar lightweight material. I want to use something equally light as to not increase the load on my joists. Any suggestions?
Should I put something over the backfill and pipes before pouring new cement? Tarpaper?
Thanks for any help! Everything I can find online about this, the only recommendation is to remove the whole slab and do a plywood subfloor, but I believe it can be done another way with less obstacles.
Tom
Tom
