WSP
Hi folks,
Just ran into an alarming situation on our home wiring that has probably been a death trap in our house for years. I found the ground wires (in this case metal sheathing on old metal wrapped 2 wire cable) to read "hot" on an inductance meter. So the housing of our ceiling lights, the screws on outlet and switch plates, and everything else reads hot. I got a 'tingle' while holding a tool and touching one of the metal cables in the basement.
So I tested the outlets on this circuit and found that they read hot on the NEUTRAL side of the outlet, and the grounded metal, as described previously. And the LAST outlet at the end of the branch (I think ) reads hot on both neutral and hot sides (and the ground).
Multimeter readings at two of the outlets show ~120V across neutral-hot, around 49V from the actual neutral to ground, and 51V from actual hot to ground. If I reverse the probes on the actual hot-ground reading it drops to like 35V.
All appliances behave completely normally on all these outlets, but I remember now the ceiling fixture in the living room would often burn out CFL bulbs—seemingly long before they should have died.
Can anyone tell me what those crazy readings are all about? I've seen in another forum someone with a 70/50 V split in a situation that I didn't completely understand, but I seem to be losing 10V somewhere in the circuit as my readings don't add up to 120...
Any insight is greatly appreciated. Last ditch effort to make this safe or I fear the bill once an electrician comes in and tries to navigate all of the back story of this old house! I may just have someone out anyway to double-check me on all of this, but I'd least like to know what is going on.
