1 toilet - 2 vents?
Discussion in 'IPC Plumbing Code Questions' started by JuanSigned, May 22, 2015.
  1. JuanSigned
    JuanSigned Member
    Jul 27, 2007
    Utah
    My local community is under IPC 2012 and if I understand that correctly a vent isn't required for a toilet. As you can see from the photo the toilet will tie into a 3" stack with no other fixtures on the line. Near the location of the new toilet there is a vent that I could tie into. From a purely functional point of view is it worth the effort?
    [​IMG]
Similar Threads: toilet vents
IPC Plumbing Code Questions TN toilet vent question Feb 6, 2021
IPC Plumbing Code Questions Toilet DWV fittings? Jan 12, 2021
IPC Plumbing Code Questions Toilet wet vented? Jan 3, 2021
IPC Plumbing Code Questions Toilet drains tee Dec 26, 2020
IPC Plumbing Code Questions How many toilets per main stack? Dec 7, 2020
