Just built a large new construction house with two 1" meters, one for the house and one for sprinkler, both with 1" pex distribution lines running 300' to the house. Haven't been thrilled with flow rates/pressure drop during use. Pressure is 56 psi at baseline. When running two showers, pressure drops to 42 psi.
Hose bibs are hooked up to the irrigation meter and get same psi of 56. I get 8.3 gpm out of one hose bib, and pressure drops to 20 psi when running. When running 2 hose bibs, pressure drops to 7 psi and they have a combined gpm of about 12. I'm not sure if this is sufficient to run a sprinkler system or not.
First, would adding a booster pump help with this issue, or would I need to upsize the distribution lines? The irrigation system and sod have not been installed yet. Rather than upsizing both lines, would simply connecting both 1" lines to the house meter be feasible, and then upsize the irrigation distribution line separately? This would save a lot on pipe/trenching cost rather than upsizing both.
