Sullivan007
Home is piped for well to main home, I just replaced bladder, pressure switch, check etc under home and home is about 100 from well. In the studio there is a bladder tank and no pressure switch or check valve. I was told the old plumber teed off of main line close to well head. The problem they were having was low water pressure and air at times, and I feel like the 2 buildings were drawing back from each other, the other plumber removed the home check valve. Pressure switch was bad, but both tanks are ok but I replace the one under main home. Both tanks are 28 psi, and the switch under home is a 30 50.
My plan was to install a new pressure switch on the studio bladder tank, dig and install wires from home to studio, wiring both switches together and install a check valve at tee. Maybe look into install water pressure regulator on both also so each system doesnt over pressure the other
The thing is I never wired 2 pressure switched together before, wiring them parallels off of the one power source. Would this setup work, pressure regulator, check valve, pressure switch etc. Any other ideas
And this is my first post
Thank you
Thank you
