GUNNAR OLSON
Hi guys. I'm in nw minnesota and the last week and a half has been -40s. I just built the house and have a 10,000 gallon tank underground with a 1 inch pex line coming into house with a check valve right when it gets inside the house....before this when the pump would turn on it would clunk really loud for 4 or 5 seconds..than run perfect...and sometimes it would start up without clunking and run correctly. .... it froze on Friday. My girlfriend turned on the water and it barely came out...I unfroze line coming from the tank underground and can not get my pump to re-prime or build pressure...I spent 4 hours trying to reprime. It did build up pressure to 40psi one time to shut the pump off, but the minute I turned on a faucet it kicked back on and wouldn't build pressure again... I've been beating my head trying to call plumbers and am at a dead end. I get it to about 20-25psi and won't go any higher. I went and bought a new mcdonald sw jet pump and wellmate pressure tank and still does the same thing. So I'm out 900 bucks already....any advice???
Bad check valve?
Bad foot valve?
Bad check valve?
Bad foot valve?
