Tintin
For shutoffs in the bathroom, I'm assuming most plumbers will use the multi-turn valve because it has been used longer, is that correct? Or are a lot of people now using the 1/4 turn ones? I suppose with the 1/4 turn ones they are less forgiving if there's an issue. And most plumbers will use the compression fitting as opposed to the Sharkbite style, correct? Thank you!
