My house gets water from a well, the current setup I have is well-pressure tank-house. I was told that adding a water storage tank would be beneficial as it would decrease the amount of times my downhole cicles on/off, so the setup I want to install is well-water storage tank-jetpump-pressure tank (as you can see, I am adding only the jetpump and water storage tank).
I don't know if I should go with a 1/2hp or 1hp jet pump. The pressure tank is 90 Gal, the holding tank is 2,500 gal, this system will be about 120' away from my house and it will be about 5' higher than my house given my land shape, I am the only house getting water from this well.
What should I go with? 1/2hp or 1hp? The 1/2hp I am looking at is cheaper and it looks to be readily available compared to the 1hp
Thank you
Thank you
