1/2” brass close nipple too long
TAPlumbing
Philadelphia
Hey!
I’ve found similar threads but none that exactly match what I’m looking for. I need to attach a shower supply elbow to a female threaded fitting, but I didn’t leave enough room for the nipple. The smallest 1/2” npt brass close nipple I can find is 1-1/8” long. I need to be closer to 3/4” long.
Here’s what I tried so far:
- I called Trenton Pipe and MoPipe and they won’t sell a homeowner a custom close nipple. They only sell to wholesalers. That, and MoPipe said they can’t even manufacture a close nipple shorter than 1-1/8” long.
- I picked up a tap and die kit. I Cut about 1/8 inch off both sides of a 1-1/8” close nipple and tried to rethread. The problem was that the taper was gone and I could only get one or two threads into both the female fitting and the supple elbow. Maybe I should have tried to use the die further? Problem is I can’t hold the nipple without destroying the threads in a clamp.
Anyone have any sage advice for this fool? I really don’t want to take the tiles down.
Cut the 1/4" off one end of the nipple, screw the other end into some sort of sacrificial fitting, then use the tap on the free end? Maybe use a drop ear elbow screwed to a length of a 2x4 for the sacrificial fitting? Or if that interferes with the tap holder maybe a coupling and a second length of pipe? You'll probably need to use an inside pipe wrench to remove the newly-threaded nipple from the sacrificial fitting ...
Thank you! I’m going to try to rethread again and see if I can get it work using a sacrificial female fitting as a holder in a vice.
TO get a leak-proof connection, you need the nipple to be inserted a decent way into the fitting...I'm not sure if you can get a proper connection with only 3/8" into fittings on either end of a nipple only 3/4" long. That's probably why the company said their minimum length is 1-1/8". Threading the nipple in the design distance does two things...makes it mechanically secure, and gets the tapered threads a chance to create a proper seal. If you just cut some off of the ends of a nipple, you might get it to seal, but you wouldn't have enough threads engaged for the design strength.
I've run into a similar issue....I was looking for a 2 3/4" long fitting but didn't realize you can only get them in 1/2" increments.
If you look at the picture, does it look like I would have enough threads to work with this 2 1/2" long nipple?
You could remove the nipple from the wall, thread on your fitting and then take that measurement.
Maybe a different shower head. Might not be ideal but better than taking down the tile. Alternatively, what is on the other side of the wall?
That looks like steel. You don't want a steel nipple in that job.
You can get custom length, tho I don't find that a the moment. you can make your own using an NPT die.
Also, if the nipple is tad short, using more tape can fill in to tighten the gap.
You need a Grohe shower wall ell (the ones that have adjustability. I haven't reviewed latest models) since they almost always have full depth adjustment that makes this a piece of cake.
There is no good way to do what you are trying to do. Don't feel bad. The design of simple/stupid shower wall ells is not your fault.
Thanks! Yes I was only using it for measurement purposes. Plan was to go brass.....?
Brass yes. Adding more PTFE tape acts like making the nipple a tad longer.
