Re: How to winterize the Drake
Posted by e-plumber on August 12, 2004 at 09:32:41:
In response to Re: How to winterize the Drake
: I installed a Drake toilet with insulated tank and soft close seat in my cabin is northern Wisconsin. When I close the cabin for the winter, what steps should I take to winterize the toilet and prevent damage from sub-zero, freezing temperatures?
Just like any other toilet.
Remove all water from the tank and bowl and pour just enough RV type anti-freeze in the bowl to create a trap seal. I usually disconnect and drain the fill valve as well but that is a whole other process to properly drain the water lines.
Replies to this post
There are none.
