| Posted by Terry Love on August 11, 2004 at 21:29:34: | |
| In response to Re: Toilet tank sweats, how to cure it. | |
![]() With cold well water, you will want to make sure that the flapper seals well. Toto makes an insulated tank toilet that should help even more. : I use water from a well. It is verrrrry cold. When the toilet tank fills it sweats and I get water on the floor under the toilet tank. Any suggestions other than air conditioning the bathroom to the same temp as the water? |
| There are none. |
