| Posted by LonnythePlumber on August 10, 2004 at 20:22:19: | |
| In response to Re: tub drain | |
: :It's CLR ( stands for calcium-lime-rust remover), a brand name product. It contains a mild acidic solution, just as vinegar is a mild solution of acetic acid. I think white just costs less! Either one will help to loosen hard water mineral deposits, which is often the cause of it being stuck. Thanks for explaining CLR. I presumed that the plunger had just come off the lift wires. |
| There are none. |
