| Posted by casman on August 06, 2004 at 09:58:09: | |
| In response to Re: Cleaning glass shower doors | |
: : Have you tried the shower cleaners that you spray on while you are in the shower? They work pretty well. All the major brands make one ( Windex, Tilex, etc.) : I'll bet when they sold you the fancy glass shower they forgot to mention that glass must be cleaned EVERY TIME you shower if you expect to maintain that bright clean look. Get the glass clean; then get the best squeegee you can find ( not the el cheapo plastic ones)..Squeegee the glass after every use, and also take your towel and wipe down any metal frames. Soap scum and mineral deposits, if allowed to accumulate, are almost impossible to remove, especially from the aluminum surfaces. I used CLR on a sponge, then rinsed with water, read label before using....worked great |
| There are none. |
