| Posted by Hube on August 05, 2004 at 08:50:10: | |
| In response to Re: Pressure Tank Sweats | |
: We just replaced a leaking galvanized pressure tank with a fiberglass one. It resides in the garage with the washer and dryer....Missouri summers can be hot and humid. : Is sweating normal for fiberglass? The floor is quite wet. The pump company says it's the dryer that is causing the problem because it is not vented to the outside. : Any ideas? Suggestions? Standing water is a real negative. : Thanks for your help. : Donna |
| There are none. |
