| Posted by Donna in MO on August 04, 2004 at 22:46:40: | |
We just replaced a leaking galvanized pressure tank with a fiberglass one. It resides in the garage with the washer and dryer....Missouri summers can be hot and humid. Is sweating normal for fiberglass? The floor is quite wet. The pump company says it's the dryer that is causing the problem because it is not vented to the outside. Any ideas? Suggestions? Standing water is a real negative. Thanks for your help. Donna |
