| Posted by Mike on August 03, 2004 at 23:44:57: | |
| In response to Re: Well pump cycles to much | |
: Ive drained the tank and checked the pressure which was right then filled it up .It reads correctly and there isnt any water coming out of the air valve.Is there any reason other than a bad tank that can cause this..Thanks I just fixed a similar problem with mine. It turned out to be a small hole had developed where the pipe connects to the submersible pump. ? Maybe ? |
| There are none. |
