Re: teflon tape joint
Posted by Dee on August 03, 2004 at 09:38:51:
In response to Re: teflon tape joint
: Dee,
: What kind of joint are you wrapping?
: Unless it has a tapered thread, you are most likely causing the leak by using Teflon Tape.
: Most connectors for lavs and toilets come with rubber seals that "don't need Teflon Tape".
This is an plastic adaptor into a water filter head. It was suppllied in a "kit" along with directions to use about 20" of tape which was supplied..Its a 3/4" plastic pipe thread into a plastic(rainfresh filter)head. Thanks for any help
Replies to this post
