Re: teflon tape joint
Posted by e-plumber on August 02, 2004 at 20:01:29:
In response to Re: teflon tape joint
: We have wrapped Teflon tape around plastic threads about 4 revolutions, but the joint still leaks water. Is there any other sealant thai I can use that would make a water tight joint? Thanks
Reply:
No matter if you use teflon tape, joint compound or both, if the fitting is not tightened properly, it will continue to leak.
Are you wrapping the tape with the directions of the threads and holding back while you tighten the fitting?
e-plumber
Replies to this post
