Re: washing machine
Posted by Gary Swart on August 02, 2004 at 15:33:10:
In response to Re: washing machine
As Terry says, the screens are very likely the case of the problem. To make sure, assemble the hose with just an ordinary rubber washer and try it. If the water flow is normal, then just get new screens. If the problem persists, then you may have debris or a malfunction in the hot water valve.
Replies to this post
There are none.
