Re: Toilet still leaks
Posted by e-plumber on July 31, 2004 at 13:03:48:
In response to Re: Toilet still leaks
: I replace the flapper, flush valve, flush valve washer, tank-to-bowl washer and bolts and washers holding the tank to the bowl. There's still a phantom flush. When I shut off the water feed, the tank water drops about 2 inches, but no more. Any ideas on what the problem may be and ways to fix it?
It sounds like you may have a hole in/or a defective overflow tube or flapper or the refill tube is inserted too far into the overflow tube and it is siphoning down the that level.
Replies to this post
