Re: Leaking shower pan upsatirs bath.
Posted by e-plumber on July 31, 2004 at 12:18:12:
In response to Re: Leaking shower pan upsatirs bath.
: I plugged the drain and filled up the shower about 2" its leaking. I hecked the water supply lines and faucet and shoer riser and they are all fine. What now Reply: Replace the pan, it's 30 years old. By the time you break open the cement and tile base and try to locate the exact spot(s) that are leaking and attempt a repair on the spot that you believe is leaking and possibly cause additional leaks/damage to the lead by breaking the tile and cement, are you going to replace the cement and tile and HOPE that you got it? An attempted repair to a leaking shower pan is not logical. e-plumber
