Pumptrol Pressure Switch
Posted by Sandy on July 30, 2004 at 16:53:44:
Recently my pump has been running for a longer period of time. It used to run for 2-3 minutes, now it runs for 8-10 minutes. The pump comes on at ~17 psi and goes off at ~40 psi. My question is (1)should I set the switch values at which the pump goes on/off (if so, how?), (2)replace the pressure switch, or (3) check for another problem. I do not believe that water supply to the pump is an issue.
Thanks for your help.
Replies to this post
There are none.
