| Posted by e-plumber on July 29, 2004 at 20:11:26: | |
| In response to Re: Lars heater soot build up | |
: Hi There, : I have a 1997/8 Lars Pool heater which has an intermittent fault in not being able to sustain a constant water temp. The thermocoupler has been replaced but made little difference. I am currently using the 'Spa' side of the control panel. I am getting a major soot build up inside the unit and have installed better cross ventilation in the pump room. There is a Spa and a pool heater sitting next to each othet. : Can you suggest a remedy? : Thanks : Ian : San Diego Reply: |
| There are none. |
