: My hot water takes forever to get to the faucets & and has no pressure and also takes a very long to get hot pleses help Thank you Larry Larry; A little more info would help. How far from the tank to the faucets? What size is the pipe -1/2" or 3/4" Is the hw line insulated? (probably not) Are you on a Well (pressure tank ) or municipal water? What heat setting is the tank.Nat Gas ,oil,or electric? Have you ever flushed out the tank to get rid of any build-up,etc. A few answers to theses questions will give you some definite results.
