Re: Re-routing drain line out of soffit into wall
Posted by LarryK on July 27, 2004 at 06:53:59:
In response to Re: Re-routing drain line out of soffit into wall
If there is a 45 there now there must be something at the other end of that 45 which means you must have a little bit of room to do something. Sounds like this is a downward drain coming into a sanitary tee at a 45. Is that correct? What is driving the change to a 90 from a 45? I guess I am trying to better understand just what the situation is.
