Re: installing a basement shower and we have a septic tank
Posted by LarryK on July 27, 2004 at 06:34:14:
In response to Re: installing a basement shower and we have a septic tank
Somehow you need to run at least a 2" line underneath your basement floor to the sewage ejector pump pit and you also need to vent the shower within 5' of the p trap. The pit should be near the exit point from your basement to the septic tank. Make sure your ejector pump drain line is installed correctly with a check valve and weep hole.
Replies to this post
There are none. |
