| Posted by hj on July 25, 2004 at 21:18:28: | |
| In response to Re: Case 3000 toilets | |
You have to remove the upper hanger bar and then reconfigure the carrier for a 4 bolt pattern using the manufacturer's hardware for the upper 2 bolts. : I have three case 3000 toilets that I am going to replace, the first of the three is on slab in my basement so a floor mount is hardly an option. I was looking at your Glenwall wall mount, will this work? It looks like the carrier would have to be changed due to the different bolt pattern. HELP!!
| There are none. |
