| Posted by jimbo on July 20, 2004 at 22:13:03: | |
| In response to Re: sprinklers | |
If YOU had changed specs in mid stream, the contractor would rightly expect an adjustment. What brand and model of valve did he install? He would have to go some to convince you that they are equivalent to Champ brass, but there are others. DId he provide you with a system design drawing with his quote?
So, if it turns out that the new design is adequate and materials are satisfactory, it seems at least that an adjustment is in order. Many installers base their quote on something in the range of $250 to $450 per zone; so 5 zones instead of 9 is a lot of money.
| There are none. |
