Re: Bath Plumbing for Dbl. Sink
Posted by e-plumber on July 19, 2004 at 22:13:38:
In response to Re: Bath Plumbing for Dbl. Sink
: Currently have single sink and want to install dbl. sink. Can I drain dbl. sink configuration to single drain outlet? Suggestions?
Reply:
Check your local plumbing code.
Some municipalities here require a double lav to have two traps, one for each basin.
I believe recent State Code changes now allow two lavs on one trap if the lavs are within 30" center of each other. Codes will vary by area.
e-plumber
Replies to this post
There are none.
