Re: Bath tub drain
Posted by Brant on July 18, 2004 at 18:13:30:
In response to Re: Bath tub drain
: : : I'm remodeling the bathroom and have romoved the bathtub. I was planning on putting in a Lasco 2 piece model in its place. My problem is from the back wall to the drain is 13 1/2". Most of the new tubs are from 14 1/2" to 15" to center of drain. I was unable to verify this prior to reomoving the cast iron bathtub and would prefer not to have to resurface or put a liner. Is there a cost effective way to move the drain, or do just need to call the plumber.
: Reply:
: The drain trap usually needs to be relocated to accommodate a new bathtub or shower stall, rarely will the old bathtub drain trap line up so it can be used. The degree of difficulty will depend on the conditions, piping materials, access, etc.
: e-plumber
: e-plumber
The opening is 10" x 12" Looks to be cast iron connected to brass ? It doesn't look like copper. The house is 38 years old. The hole is filled with Tar.
Replies to this post
There are none.
