| Posted by LonnythePlumber on July 18, 2004 at 18:10:34: | |
| In response to Re: Cutting concrete for drain | |
: I am planning a wet bar in my basement and want to tap into the existing three piece rough-in. The run will be between 25-30 feet. It is a straight shot across an unfinished room to the drain but will need cut a channel in my basement floor. What would the best way to cut the concrete channel and how difficult? What would be a reasonable charge to have it done professionally? : Thanks, : Kirk You can call a concrete cutting company and get pricing. Remember to include your cross cuts. You could also pump the water overhead although this would not be as maintenance free and below slab. LonnythePlumber |
| There are none. |
