Re: Pressure tank installation
Posted by Hube on July 18, 2004 at 09:20:39:
In response to Re: Pressure tank installation
: I had to replace my pressure tank with a new Well-rite tank. I thought everything was okay as it seemed to be working but I noticed that my tank sweats where the water is in the tank and there is only about two inches of water in the tank. I don't know how to remedy this so that more water goes into tank. I think the water must be coming straight from the well sort of by passing the tank. Coveylane; To get the most water in the tank, make sure when its empty there is approx 2 psi of air below the pumps cut-in setting. Example; cut-in= 30....Tank (empty) psi= 28... Hube
Replies to this post
There are none. |
