Re: Pressure tank installation
Posted by Hube on July 18, 2004 at 09:16:32:
In response to Re: Pressure tank installation
: I had to replace my pressure tank with a new Well-rite tank. I thought everything was okay as it seemed to be working but I noticed that my tank sweats where the water is in the tank and there is only about two inches of water in the tank. I don't know how to remedy this so that more water goes into tank. I think the water must be coming straight from the well sort of by passing the tank. Coveylane: To eliminate the sweating, wrap the tank in a blanket of "air foil" insulation. (this is a blanket wrap composed of 1" of fiberglass with a silver foil facing. Use foil tape around the upper edge to seal it. It only has to be approx 2" above the full water line..Good luck...Hube
Replies to this post
There are none. |
