| Posted by greg on July 16, 2004 at 00:58:13: | |
| In response to Re: Toto Drake toilet product review | |
: Just had a Toto Drake installed and second one will follow later today. The first one flushes but not much water in bowl. Can that be adjusted? : Anyone else have trouble with tank wobbling or rocking? Contractor said you can only go so far with tightening bolts without cracking the porcelain. Suggestions? Shim that thing! I had a rocker & shimmed it with pvc slivers cut with a razor knife from that Cellulose PVC moulding you can get at any of the BIg Box Stores. Then caulk around for a steady ride!
| There are none. |
