Re: Grounding a hot water tank
Posted by jimbo on July 15, 2004 at 23:45:15:
In response to Re: Grounding a hot water tank
This is really an electrical issue and should be addressed to the electrical inspector in your area. In some areas the cold water pipe is used ground the electrical system. I have seen it necessary to "jump" devices in the cold water system which interupt electrical conductivity; i.e water meter, water softener. I am not sure why the need to jump the WH. CHeck with local authorities.
Replies to this post
There are none. |
