Re: Causes of Failure of Pressure Relief Valve
Posted by jimbo on July 14, 2004 at 15:35:59:
In response to Re: Causes of Failure of Pressure Relief Valve
This is just a suggestion, since you haven't told us the mode of failure, or what before/after pressures were. However, it is alomost axiomatic that when a water system is worked on... such as installing new meters... dirt and debris become dislodged from fittings and pipes and those particles find there way to trouble spots, such as faucet aerators, PRV valves, etc. Have you tried just disassemble and clean?
