Re: Installing a tub shower
Posted by e-plumber on July 12, 2004 at 07:27:57:
In response to Re: Installing a tub shower
: I have a rental house that I am remodeling, to now sell. The house was originally built with washer and dryer area in place of a standard tub/shower in the master bathroom. It has bi-fold doors that cover the opening. I would like to remove the doors and install a tub and shower surround. The basement is open below. Plumbing is run to the left side of the back wall where the washer sat.
: Any suggestions or concerns with this project? The goal is to increase the appraised value as well as make the home more appealing.
Most likely it can be done, especially if the basement has exposed water, drain and vent lines. A project as this would require the job to be filed and inspected by both a licensed electrician and a licensed plumber.
A Building Dept. official should inspect & approve the conversion.
Replies to this post
There are none.
