| Posted by Greg on July 11, 2004 at 21:33:59: | |
| In response to Re: Offset Flange - backwards? | |
How about backwards? I've got a soil pipe that is roughed in at 12.5 inches and the toilet is behind a door, so that I've only got 27.5 projection from the wall. Could I "cheat" an extra 1/2 inch by using an offset in the opposite direction (towards the wall)? : Can a 1 inch offset flange (cast iron) be used to offset sidways? Or is there something designed for that. I have cornered myself on a remodel and either need a toilet with a 161/2inch wide tank, or need to slide the flange over @least 1 inch. (or , some freshly spackled and painted walls need to be undone : (I have found a 17 1/2 wide tank Kohler Memoir)
| There are none. |
