| Posted by LonnythePlumber on July 08, 2004 at 23:17:48: | |
| In response to Re: Water heater pressure relief valve | |
: I live in a condo above another condo and need to protect from flooding from water heater. Two yrs ago I had a plumber install a new heater (6yr tank 1 yr control Bradford White) and drain pan patched through the air conditioning drain. Yesterday the relief valve went and almost flooded me and my downstairs neighbor. The plumber said I put the temp too high on the heater. Also the drain did not work. He replaced the pressure valve with a 180 one. Should I get a better water heater? Should it go so hot it blows the valve(it had gone to 150 degrees). What about the drain pan? Can anyone help? Thanks! Perhaps you should check with your jurisdiction's
