Re: Drilled into a PVC pipe
Posted by Gary Swart on July 07, 2004 at 12:11:28:
In response to Re: Drilled into a PVC pipe
As a devout DIYer, I wouldn't either. There are easy to use sliding couplers that make this repair a snap. I have use several on irrigation lines, and they have to hold under pressure that a drain does not have. The fiberglass patch may be fine, but the sliding coupler would be not only the proper way, but would be much faster to install than messing with fiberglass.
Replies to this post
There are none. |
