| Posted by LonnythePlumber on July 07, 2004 at 10:12:30: | |
| In response to e-plumber question | |
: I was hanging some shelves in my garage and drilled into a drainage pipe from the utility sink in the adjoining room. What is the best way to patch it? e-plumber. Do you think it would be okay to cut through the pipe at the location of the hole and install a solvent weld coupling? I usually have enough slack to move the vent pipe up and down to make this joint. LonnythePlumber |
