Re: heated kitchen cabinet?
Posted by LonnythePlumber on July 06, 2004 at 13:09:08:
In response to Re: heated kitchen cabinet?
: For proofing dough? Just a wild guess. : : Recently bought a farm house built in the 40's. when beginning to remodel i found in the a floor to ceiling kitchen cabinet something I am unfamiliar with, hoping to get an explaination. the cabinet, approc 2'x7' floor to ceiling has coppper hotwater tubing running on the interior surface of the cabinent at the edge of the adjustable shelve in two courses. Thi8s tubing is plumbed to the hot water heat in the basement. The floor of the cabinet is ventelated, the shelve have 4 to 6 1" holes drilled thru the surfaces and at the top the cabinet is ventelated to the outside. Can't imagine the function of this.
: : : : Clueless in Seattle : : Craig The water heater could have been installed in the closet. When the fuel efficient heaters came out in the 80's ?, the solid wall insulation made the heaters wider and we could no longer fit them into tight closets. LonnythePlumber
Replies to this post
There are none. |
