| Posted by Deb on July 06, 2004 at 11:04:02: | |
| In response to Re: plumbing | |
: hi i was told that if i add a sink to my house i can run a vent up the wall.i was thinking i could run it into the attic and finish later when i do my roof? then tie the drain part to a vented stack if that makes sense? can i run it up the wall ?thanks grant rogers Your description of what you are trying to do is not understandable. This usually indicates that you should consider having a plumber at least look at your situation to advise. |
| There are none. |
