Re: relocating drain and supply lines
Posted by Deb on July 06, 2004 at 10:57:24:
In response to Re: relocating drain and supply lines
: I've got a plumber coming tomorrow, and in prep, I've gutted the bathroom. What I discovered was that the vent and supply lines were brought up in what now is in the room space, not in the wall. I've used these guys before, so I have confidence that they can do the job, but since the supplies are offset probably 4' from where they need to be, how do you get a piece of pipe through the wall - several smaller pieces - flexible pipe, what? Want to know what would be best, so I can decide which option is the one I want - I don't want to have to do this again!
Since you have a plumber you trust---you should trust him. I am rather with hj on this. No one that is not there to look at the job can advise you better than a plumber (you say you trust) that is on the job and can see what you have to work with.
The Pipewench
Replies to this post
There are none.
