| Posted by Hube on July 04, 2004 at 19:13:56: | |
| In response to Re: CEPTIC TANK CLEANING & ROD IRON FENCE REPAIR | |
: You should check to make sure the fence is actually wrought iron and not steel. Many times steel is mistaken for wrought iron. If it's painted and or rusting, it's probably steel. Davydo; Steel or wrought iron won't make any difference to a pro welder if it has to be welded. He will know how to weld it. Hube |
