Re: How do I remove stuck kohler tub divertor that leaks
Posted by hj on July 01, 2004 at 09:06:19:
In response to Re: How do I remove stuck kohler tub divertor that leaks
There are several different types of diverters, but most do not come out by removing the stem nut. There may be a larger "nut" further back that removes it. Lime deposits also seldom prevent it from being removed, they only make it difficult to operate it. : I have a wonderful old shower/bath kohler faucet -- that has three knobs Hot, Cold, Divertor. When you try to divert the water from the : bath to the shower half of the water continues to run to the bath, making the shower pressure very weak. : I have removed the knob and the stem nut and gently (as not to break anything) tried to screw out and : also pull straight out the stem, to no avail. I figure there are lime deposits on the inside of this divertor. : Would it be possible for you to instruct me on the proper technique on removing the divertor so that I can : proceed with confidence. That way if I still break something I will know that I was at least using the right : technique. : Thank you for you assistance : Chris : Please email me with any answers mwmwmfilms@yahoo.com :
Replies to this post
There are none. |
