| Posted by Davydo on June 30, 2004 at 21:56:22: | |
I'm installing a basement bathromm. Ive located the waste line at the backwater valve where the line exits the house. The valve body is cast steel. However, all other lines above the concrete floor are ABS. I won't know until I cut the floor where the transion occurs. It seems that I may have to tie in to 4" Dia. cast steel pipe with the ABS I'm using for rough-in. I'm concerned with getting the best joint possible. What type of joint fixing do you advise. |
