| Posted by jimbo on June 30, 2004 at 09:54:05: | |
| In response to Re: Whistling Pipes | |
: You may have a small leak somewhere, perhaps a toilet fill valve which does not shut off; this small leak may be causing the vibration/squealing in your presure regulator diaphragm. Turning a faucet on, the regular flow does not cause the noise. So, you need to look for a leak; and the PRV may also need to be serviced or replaced. |
| There are none. |
