| Posted by LonnythePlumber on June 29, 2004 at 22:35:54: | |
| In response to Re: ABS Glue | |
: : Well, it's done and you will sleep better! We have to be careful not to "impersonate" each other. I don't want to catch hell if you should happen to piss off Sylvan! I would water test your piping before the concrete pour. You are evidently not using a box out for the drain as is customary. It is not only hard to get the tailpiece within an 1/8" but sometimes the strainer is below floor level. LonnythePlumber |
| There are none. |
